TwinTurbo.NET: Nissan 300ZX forum - Nismo thermostat. Sorry fat fingered it (n/m)
ztunerz
on May 11, 2013 at 9:00 PM
If you are using a nismo Eurostar it needs to be 160 or
posted by ztunerz
on May 11, 2013 at 08:58 PM
What is the minimum temperature required to be out of the
Evan_Wright (Ca)
13:42:24 05/10/13
it depends on the tune
aliaZ
14:02:56 05/10/13
Is there any way to read that parameter from the EEPROM
Evan_Wright (Ca)
14:28:22 05/10/13
I would think that 174 degrees is plenty warm.
Summeronthechain (MN)
14:13:31 05/10/13
11-12mpg. I've installed brand new oem oxygen sensors
Evan_Wright (Ca)
14:24:39 05/10/13
I would def try swapping out an ECU
15:17:22 05/10/13
Injectors are fairly new nismo 740's. I pressure tested them
Evan_Wright (Ca)
15:38:32 05/10/13
What about a full fuel system check? I.e. return lines?
TriniTT
21:51:50 05/10/13
That's something I haven't considered. If it
Evan_Wright (Ca)
22:08:53 05/10/13
A simple fuel pressure gauge should determine this, right?
22:25:53 05/10/13
Engine coolant temp is very important to the ECU, it >>>
ZUL8TR
06:06:24 05/11/13
PS per Nissan specs the thermostst start to open >>
ZUL8TR
06:24:37 05/11/13
The thermostat and coolant temp sensor is oem and was
Evan_Wright (Ca)
11:30:52 05/11/13
ztunerz
20:58:03 05/11/13
Nismo thermostat. Sorry fat fingered it (n/m) -
ztunerz
21:00:27 05/11/13
80 degrees celsius
Dane (Houston)
00:13:19 05/14/13
